  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i went to a posho party in an east perth penthouse once and he had a slushie machine in his kitchen which made tequila slushies - with a combination of tequila and sambuca why i wasnt sick that night i dont know!! but i was only 17 at the time and i had a deadline of being home at dawn haha lets just say when i woke up at 9am my parents had left 8 mesages on my message bank! I was in soooo much shit when i got home!
*still hiding behind soapbox to escape from bullys wrath* haha yeah they are a nice car reaaally haha. im not convincing am i?!
u know i love ya and your car bulls!! even if it doesnt have the sacred nissan seal!
Originally posted by Pva_Glue
last time when chick stripped infornt of me was @ the hhmmm rather not say...
it was fun ;)
hahaha i was taught by a guy mate of mine how to strip properly! yes we had an interesting relationship to say the least!
yer i know im only here as someone has to have good taste on this forum --- and i dont mind skylines or 180sx's myself think of getting the wife one
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
