Originally posted by angel
Ken are you the one who teaches driving? Would like a track session to learn how to handle my car better.
Think we could get enough people to have a track day?
they've done it - speak to micko - me and 33spec2 are going too. The aim is to hit as many orange cones as possible right haha?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mmm told by my driving instructor i was the only girl he taught that drove like a guy :P so take that anyway u want. But as for clutch rider - havent driven a manual in a while unfortunately so i could be a little rusty. i miss manuals *sniff*
What , so you drove with your legs apart , scratched your crotch and farted ??
:P
Cheers
Ken
Originally posted by 33Spec2
hahahaha if its 2 hit the orange things im gonna b a winner! :P
yeah double postings sorry! wat i hav 2 say is so special i hav 2 say it twice! :P
If i get to spin out once during the day i will be a happy girl!!! oh oh and there shall be no brake pads left by the end of it - haha if im gonig to spend $185 i might as well be able to drive like a manic and enjoy it :)
Angel - no details set in concrete to post - its something that micko talked me into while intoxicated one night haha
Ken, is there a double meaning in everything you write, or do I just look too hard?
Where , when , who me ??
Nope , I'm innocent , it's just your Baileys fueled mind that is working on your mind.:P
* If she believes that , she well pissed *
Cheers
Ken
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
