  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
yes but still paranoid
the fatboy has someting against me cause he can only pull 15sec in pauls car hehe
He shouldn't complain if he can pull longer than pwpt60secf.
Oh , you mean drag race .
Sorry
Cheers
Ken
Originally posted by Micko
Macka - you didn't answer my earlier question - how is your car progressing? In the panel shop yet or not?
Macka's prolly back on the phone trying to boost his after hours sexline to raise some moola.:P
Cheers
Ken
someones on a roll tonite
so ken the ricers is at the warf
hmm might go check her out
:P
yep , ricers on the wharf. Should be able to see the wing from Freo bridge I have been told.
Cheers
Ken
Originally posted by macka
postwhore and riceboy Moderator
not...
postwhore, and riceboy moderator
anyway...ken...
im not surprised :P
Ahhhhhhhhh , I seeeeee
Well moderate pwpt60secf.
BOY could he do with a good moderation .:bahaha:
Cheers
Ken
Hey guys - the missus is watching the end of that jow Moolyonaire or whatever it's called.
Bet he enjoyed making the show - that's all I gotta say about it!
Hmmmm , ditto
Cheers
ken
did u see the jugs on the last 4 all D or DD's hehe
kylies watching that atm
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
