  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
yes but still paranoid
the fatboy has someting against me cause he can only pull 15sec in pauls car hehe
He shouldn't complain if he can pull longer than pwpt60secf.
Oh , you mean drag race .
Sorry
Cheers
Ken
Originally posted by Micko
Macka - you didn't answer my earlier question - how is your car progressing? In the panel shop yet or not?
Macka's prolly back on the phone trying to boost his after hours sexline to raise some moola.:P
Cheers
Ken
someones on a roll tonite
so ken the ricers is at the warf
hmm might go check her out
:P
yep , ricers on the wharf. Should be able to see the wing from Freo bridge I have been told.
Cheers
Ken
Originally posted by macka
postwhore and riceboy Moderator
not...
postwhore, and riceboy moderator
anyway...ken...
im not surprised :P
Ahhhhhhhhh , I seeeeee
Well moderate pwpt60secf.
BOY could he do with a good moderation .:bahaha:
Cheers
Ken
Hey guys - the missus is watching the end of that jow Moolyonaire or whatever it's called.
Bet he enjoyed making the show - that's all I gotta say about it!
Hmmmm , ditto
Cheers
ken
did u see the jugs on the last 4 all D or DD's hehe
kylies watching that atm
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
