Originally posted by Strich9ine
goddam joe, turn off that img in your sig' it's pissin me off....
next thing you know we end up with every newbie posing 1024x768 images in thier sigs like the supraforums....
BAH!! wish they never turned that on!
well it wasn't ur decision prank was being hounded from all over for it, pics will have limits and u can turn sigs off in your profile so its win win for eveyone
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by CC
Joe
Mine is the same colour as that - pretty impressed with the paint work on mine - flawless!!
What is the value of one of these you reckon?
Would it be easy to put a turbo on one of these later down the track? I have been told its not that difficult? Any one know an approx price?
How / where do I find out about the cruises? It would be tops to perve on more skylines and get some tips from you enthusiasts....
See See
nah leave as NA dotn turbo it! it will cost you arms and legs!
if you want put RB26DETT depends on the price of the GTR engine.
If I knew you early I would have sold my BLITZ ECU and filter etc..etc. :D too late now.
only you can do is go raicey, Performance is out of the window with NA skylines.
jsut get decent sound system and body kits, you can do some engine mod but not much...
cheers
JOe
Originally posted by GTS-t VSPEC
Kym,
I just want it privately, an FTP address where Ken could send it and me retrive it would be good:D
See'ya:burnout:
ahh well..
If you send it to me, i can host it for you. I can't give out the password to the FTP account hey :D
lemme know if you need my help :uh-huh:
adam - when i cleaned the pipes on saturday morning it was terrible the amount of oil that was in there! admitedly it may have never been cleaned in nearly 100,000km, but the intercooler must be half bloody full!!
Hey gradenko ahs been running the coke bottle for around 6mnths now and hasnt had a worry. I am thinkin about doing the same thing but im worried that it might get a little heat soak casue of the rather small engine bay. Hey adam32 i might take that can off ya if the other guy dont want it.:D
It basically just a can with 2 holes in it right? cant be that hard to weld one up. Well if i had a welder :D
Who give dam how it looks? there is oil and stuff all over the palce anyway everything is black. What u gonna clean ure engine bay??? who the hell does that??..........oh wait....whups;)
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
