  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh but i got no gtr here im not pulling over 400rwhp....sorry fwhp (dammit!!!!) i think heat is the only concern. if any1 has ever smoked the whack tabacy b4 they know its not hard to get a good seal witha hose in a coke bttl :D
What hick special edition? something i should know?
I think hes at Uni. He broke his phone on Fri last week and hes all bitching and moaning about how the pnansonic is soo great and the nokia is so crap. So to demonstrate this point hes throwing the nokia at the floor and it breaks too. now he has no phone not even his "crappy" backup nokia
*runs for the turn sigs off switch!*
Subject: [wa_rally] (unknown)
You know you own a Street Machine when:
The emissions test guys start laughing as soon as you pull into the
bay
You can't drive your car in the rain
You can't drive your car in the sun
Your missus is afraid to drive your car
You are afraid to drive your car
You spend more on tyres than on food
Your council decides not to re-pave your street with that new
rubberised asphalt becuase you've already "done such a good job of it"
You spend more on car insurance than house payments
Your insurance company has to create a whole new acturial table to
cover your and your vehicle
You have never argued with your wife over making the mortgage payment
or buyi! ng that new set of headers while they're still on sale
You see a picture of your car taped to the bulletin board at your
local police station
Your local council has passed an ordinance making it illegal for you
to even enter a school zone unless you are on foot
Traffic advisories are issued whenever your car is spotted during
peak hour
Your mechanic names his new second shop after you
You have speed shops on your telephone speed-dial
You're tempted to wear your fire-suit just to drive to work
You refer to the intersection at the end of your street as Turn 1
You get pulled over for doing 120 in a 60 but the cops will let you
go if they can look under the bonnet
News footage of cops chasing you is used as a training video for the
highway patrol
Your face looks like you are riding a NASA centrifuge when you drive
the car
You need parachute braking
There is no possible way t! o "sneak-out" of your neighbourhood at 6am
Your pets scramble for their hiding spots as soon as the garage door
is opened
You wear earplugs in your cars
You find out that stock side mirrors vibrate at ordinary highway
speeds - more than 240 km/h
The exhuast pipe has a larger diameter than the tailshaft
Your fuel pump can be used to water a golf course
Your engine idles at 2800RPM
You aspire to crack 8 mpg one day
The airport on the other side of town complains about the noise
coming from your garage on Saturdays
The fire brigade has showed up at your house because alarmed
neighbours reported smoke billowing from your garage
cheers
Neil
and to top nizmos sig -
"You know the world has gone crazy
when the best rapper in the world is a white guy,
the best golfer in the world is a black guy,
France is accusing the US of arrogance and
Germany doesn't want to go to war."
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
