  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I don't think the coke bottle would look to flash though:p
Best thing about the coke bottle is it can be jammed into the tightest, darkest spot in the engine bay. Instant stealth mod :D I've had several coppers look in my engine bay and not one yellow sticker yet.
The Mines guys only *wish* they had a coke bottle. Think of the weight saving :D Actually, I've seen more than one fresh import with small juice containers as catch cans, so maybe the coke bottle isn't the right one for the job. Theres more research to be done in this area, I'm off to buy a Mountain Dew to test with :)
I've seen a decent metal can for $100 with filter, I'll post a link later. Anyone know how much Cypher want for one?
Hehe, the tight-arse import mods, maybe we could start a thread of mods you can do that cost less than $10:p
See'ya:burnout:
yeah theres one of them at SDU so been there done that just ask rev210 hes a big contributer to that one
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
