  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Yes Macka they've all seen it:p
Troy, Make her stop, she being mean:p
Ken, Yeah burn it, I'll organise to get it off you somehow:D
See'ya:burnout:
not as mean as you have been today shithead! :shake:
1 Yes Macka they've all seen it:p
2 Troy, Make her stop, she being mean:p
3 Ken, Yeah burn it, I'll organise to get it off you somehow:D
See'ya:burnout:
1 not everyone
2 u was mean to her first
3 ken and a burner this should be fun
Originally posted by macka
u mean what codec not res dildoheadskyzerr
anyway before im in trouble have a good night men (including niz)
Wont be able to whore tomorrow i have school!!!
Paully ill organise the cottage :)
night night
codec smodec
:D
u at skool wows
paul - no u havent. Havent you learnt that if you cross a chick she will hold it in her memory to constantly use against you? no wonder u have no luck with women u forget the golden rules :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
