  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
me and my friend spooked a mate of ours out once - pretending we were from some cult looking to recruit him thru emails etc - spooked him cos our little cult knew so much about him and he hadnt a clue who it was - nearly 2 years later we finally told him - shouldve seen the look on his face. ahhh high school pranks.
Anyway report it but i really think serious thieves n murderers would not mess around with notes!
good point ill just hav 2 wait and c wat happens!
it wouldnt b paul he knows it a n/a!:(
Hmmm , Mackas chasing some panels and pwpt60secf said he was gonna supply .;)
Just joking , I would never accuse anyone but if I found out someone did , would not waste my time calling the cops
*We have ways to make you sorry*
Cheers
Ken
Originally posted by skyzerr33
yeah ken does a strip o gram for u
hahaha classic troy. instead of verbally beating them to a pulp next time i'll just let ken take over. :(
almost my bed time to fellas ;)
No was thinking more of locking them in the back seat after Macka has had another boozy night combined with a particularly nasty vindaloo curry
Cheers
I have gasmask
Ken
Yep , think I will join you.
Going to bed that is.
I mean I will be going to bed and so will you... in separate beds... not at the same address... ohh never mind.
Goodnight all
Cheers
Ken
haha ken. unfortunately i take up 25% of my double bed my cat takes up the other 75%!! Shes got a big arse and if you accidently kick her she latches onto your leg - ouch!
Hmmm , I dont mind an active ***** . Hehehe
Cheers
Ken
micko pops in again for a goodnight call
hey micko can tandi refund money via an eftpos machine?
cause kylie got the wrong modem to start with went back got the right one which was $20 cheap and they refunded via the eftpos machine
didn't think u could do that
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
