  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
me and my friend spooked a mate of ours out once - pretending we were from some cult looking to recruit him thru emails etc - spooked him cos our little cult knew so much about him and he hadnt a clue who it was - nearly 2 years later we finally told him - shouldve seen the look on his face. ahhh high school pranks.
Anyway report it but i really think serious thieves n murderers would not mess around with notes!
good point ill just hav 2 wait and c wat happens!
it wouldnt b paul he knows it a n/a!:(
Hmmm , Mackas chasing some panels and pwpt60secf said he was gonna supply .;)
Just joking , I would never accuse anyone but if I found out someone did , would not waste my time calling the cops
*We have ways to make you sorry*
Cheers
Ken
Originally posted by skyzerr33
yeah ken does a strip o gram for u
hahaha classic troy. instead of verbally beating them to a pulp next time i'll just let ken take over. :(
almost my bed time to fellas ;)
No was thinking more of locking them in the back seat after Macka has had another boozy night combined with a particularly nasty vindaloo curry
Cheers
I have gasmask
Ken
Yep , think I will join you.
Going to bed that is.
I mean I will be going to bed and so will you... in separate beds... not at the same address... ohh never mind.
Goodnight all
Cheers
Ken
haha ken. unfortunately i take up 25% of my double bed my cat takes up the other 75%!! Shes got a big arse and if you accidently kick her she latches onto your leg - ouch!
Hmmm , I dont mind an active ***** . Hehehe
Cheers
Ken
micko pops in again for a goodnight call
hey micko can tandi refund money via an eftpos machine?
cause kylie got the wrong modem to start with went back got the right one which was $20 cheap and they refunded via the eftpos machine
didn't think u could do that
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
