Originally posted by skyzerr33
this makes three padawan :D
I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd .
PLEESE don't take me away , AHHHRGG the force....
Cheers
no nerd
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
hey ken - can you email the vid footage?
Sorry Sneeza , it's 13 meg and we tried last night a few times.
Burnt a CD . I am sure Paul can burn one for you if you PM him.
It's not much and you can't see my speedo ( thank god ) , but the trees and light poles starting moving backwards at a rapid rate. Hehehe.
Cos we weren't speeding so thats the only explanation I have.:D
Cheers
Ken
Originally posted by 33Spec2
on private roads rite!:D
Nah public roads but I'm not responsible for backward moving light poles.
That's the councils problem . I can't help it if they don't use enough concrete and the poles run off.Hahaha
Cheers
Ken
I don't think i have ever gone that fast in a car before hahaha
Yea must admit , we were up there.
Have gone faster in Targa on a road that was 1/3 as wide and over blind crests.
Thank goodness for pace notes and closed roads.
cheers
Ken
someone has 2 take me 4 a ride next time! someone who can drive better than me (pretty much everyone) !
Russ , going fast isn't the prob , it's the slowing down for the situation ( ie hazard , corner etc ) is what catches the novice or unwary.
You could have a run with me but I crash better than anybody I know.
Cheers
Ken
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
