  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah paul.
rego in about 2 week Im guessing.
in the mean time Im gonna need to:
figure out what the rules about pods are and possibly fit the standard airbox
raise the suspension about half a foot so I can actually travel around corners without ripping the quarter panels off,
and fix that manfold so it sound like a badass skyine instead of a badass sodastream
Two little kids are in a hospital, lying on stretchers next to each other,
outside the operating room.
The first kid leans over and asks, "What are you in here for?"
The second kid says, "I'm in here to get my tonsils out and I'm a little
nervous."
The first kid says, "You've got nothing to worry about. I had that done
when I was four. They put you
to sleep, and when you wake up they give you lots of Jell-O and ice cream.
It's a breeze."
The second kid then asks, "What are you here for?"
The first kid says, "A Circumcision."
And the second kid says, "Whoa, Good luck buddy, I had that done when I was
born. Couldn't walk for a year."
I have a question for you.
You are the President of the U.S.A. and you've just learned that there is
an asteroid headed for France that will wipe out their entire country. It
is scheduled to hit about 2:30 am, in just two days time from now.
You have enough ships and military personnel nearby to evacuate them
safely, but they are on stand-by in case they are needed in Iraq.
Your question: do you set the VCR to record the asteroid hitting France, or
do you stay up to watch it live?
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
