  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
one word - christina aguilera yuk - i thought you guys like classier girls than that - well i know the guys i normally hang around do - the tart look does nothing for them - they've even banned me from wearing white pants because they reckon it looks like a 13yr old trying to get into a club and it wasnt til a really good example walked passed that i had to agree and gave them up forever.
Just look up french knickers in shopping site or something im sure they'll give examples
dark and darker (wierd couple?!) - already have enough rice.. stickers are bad.. :P want funky under bonnet stuff.. catch can should be on it's way - speaking of that Adam32? u around mate? wheres my f*&^%kin can? hehehe :)
sure.. i agree.. but still.. it does look pretty cool..
white pants are soo ugly...
dark and darker?? wtf?
Originally posted by GTS-t VSPEC
Cam,
Have you got your cam covers polished? Mine will be ready next week:D
See'ya:burnout:
whats that worth to get done paul? can you recommend anyone? (ie - where were urs done?)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
