  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey Niz
The car is a total write off - I know paul has told you about it. But it was a t-bone accident and I launched off his bonnet went on two wheels through traffic pole and yeah... the engine was on my feet and I couldn't get out. it was so scary. I don't know how I got out of the car - i ripped my feet out - which prolly did more damage - and jumped out the window and started vomiting.... it was really pretty hahah
hey dark
Aw11 - nope all the witnesses were saying it looked pretty cool hahaha I wasn't thinking that at the time. Someone said congrats on the driving skills.... i don't think I was driving I was just holding on like all hell!
I didn't even brake - the went straight through the lights so fast
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
