Originally posted by Kyles
na i do... my tummys stacked it on since ive moved out.
I think i just need to exersize.
Gez i rember when i was size 8!..
I like size 10. thats a good size :P
was the top half of ur torso ever a size 8/10?
hehe..
joe: what brand u looking at?
panasonic/sony r usually bst
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah haha dont worry i stacked on a bit since my glory days of size 8 - mainly round my butt and hips - aghhh im still careful with what i eat says me currently munching on hungry jacks - i just need to exercise more sooo unfit haha
Originally posted by Pva_Glue
What ever as long as it players DVD... :P I got no clue with DVD.
mp3, multi region, dolby sounds etc..etc.
just go down to ur local electric goods store.. [not a country bumpkin one] - like.. harvey norman or sum shit
You are sooo not Fat!
nor you Kyles
you both has big Bone.
when you cant see your toe or touch them then you need to start to worry/exercise :P
damm I didnt for run today, I feel soooo far :)
cheers
Joe
compared to what i used to be dark - i am :P the advantage is that ive got a bit of a bust now at least - actually all the females in my family have kyles size bust- except me somehow i lucked out in the gene pool!
compared to what i used to be dark - i am :) the advantage is that ive got a bit of a bust now at least - actually all the females in my family have kyles size bust- except me somehow i lucked out in the gene pool!
aww.. poor lauren.. at least u got the looks and the body :(
No dark my top wasnt eva that size... cheaky bugga... they always been big.. gez i think i was a d when i was 12!
12.. :P omg.. u were the popular one in school yes?
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
