  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Gradenko
lol at the cow joke.
> So i sez "Listen buddy, your car was upsidedown when we got here and as for your Grandma, she shouldnt have mouthed off like that!"
Whats this from?
can you swing a sack of door knobs?
can I !!!
well, here's a sack. You'll have to supply your own knobs.
Originally posted by zanda
theres probably a trade off between a big nut that makes a bigger heat sink and is therefore better able to cope with extreme temps, and one which is munted already but is bigger.
too much info!! time for beer.. :D
will talk to u about it tomorrow bud.. we'll sort something out..
bye all..
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
