  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i used to know them too - was going to get them to do it while they were at new town one day but i no longer work there so thats no much good!
been like that for 6 months now - so no it aint getting any worse :mad:
yeah. that'd be good.
Car is in a million pieces, but it looks shithot. combination of factory silver paint, muffler-dragging suspension and buddyclub P1s make for a surprisingly sexy combination.
May need to address a few minor panel issues and the front fac-option spoiler too. will be a good excuse though.
hopefully by then the full stereo transplant will be complete too.
paul,
I am a **** for cheesy rice culture.
First and foremost I think mine is probably a cruiser. it will be made to go fast in time, but will incur the wrath of my penchance for extremely loud music.
In the immediate future its more likely to be a fast ricer tho - if you had to put a label on it.
engine work (once everything goes back in)
turbs back exhaust, HKS pod, HKS AFR, cold air box to come in the VERY near future (maybe as soon as next weekend, depending on my saturday night).
other: tein coilovers on each corner (with associated minor damage to the front quarter panels from rubbing associated with going from 215/35s to 245/45s!), and my nice rims.
coming: bov, boost guage and bleeder of some descritption likely to follow soon.
skyzerr33, have you checked out the boots jay95 is selling? Don't know how they compare to pauls ($15 for Pauls may be better value), but the leather Jay uses is good stuff. Hell of a lot better than the factory vinyl stuff. Lets compare boots at the next cruise :mad:
Oh yeah, my peeling dash pissed me right off, so I sat down and painted it over the holidays. Its not rice, I swear!
RIIICEEEE!!!!
what color is it now denish?
black = not rice something else equals rice
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
