  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
yeah cam, this is the adrian u met yesterday! i'm saving up at the moment as well, so when i get on tafe holidays send my car in for sum work, number one priority is to get the bodykit sorted out!
adrian :P
got any pics of urs adrian?
my plan for cosmetics is to loose large rear spoiler, replace bonnet with carbon fibre one, drop car by 2 inches, get rims blasted and powdercoated a dark grey colour to match bonnet..
should have driftspec look.. :P
nah i haven't got pics of mine!, but i think i caught joe taking happy snaps while i was at work, to me it looked like he was licking my exhaust lol
anywasys i got a trust front bar to put on waiting for some nice sideskirts! arghgggg still haven't found any unique ones then prolly a veilside rear bar and no rear wing for a while i hate the standard one! thats stage one of the body
stage two involves a bit of wide body styles! :P
adrian :P
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
