  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
I hear Paul can get a good deal on those!!
Might I suggest that the scheming of western salon-ness might begin on the cruise on the 11th?
Spoke to my associate from Silvia WA last night. theyre putting 15 cars in.
15?!?!?! jeezus.. we should get together a large contingent then i suggest... need some r34s too... :D
my mum says shes sending me over to an island or somewhere out of aus for my wedding so she doesnt have to invite my dads family *meow*
Well you can definately go holiday mode - barefoot in shorts and tank top in midland gate just like the locals.
hmmm they are suppose to be quieter when they are hot not louder i thought - yeah me and my mechanic went doing mini burnouts to try to get them hot enough to stop squeeling - didnt work but had fun :D
koh sumoi - i was suppose to go there haha with a friend because he gets flown over there by his fathers company to spend time with them - dad works on an offshore oil rig. But i kinda started going out with a guy and that was the end of that idea.
Originally posted by GTS-t VSPEC
15 cars is alot, I don't think we need to over do it, beside, most of those Silvias are plain and boring looking:D
See'ya:burnout:
true.. :D
i'm sure 8 or so lines next to each other will cause a decent stir... :(
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
