  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
I hear Paul can get a good deal on those!!
Might I suggest that the scheming of western salon-ness might begin on the cruise on the 11th?
Spoke to my associate from Silvia WA last night. theyre putting 15 cars in.
15?!?!?! jeezus.. we should get together a large contingent then i suggest... need some r34s too... :D
my mum says shes sending me over to an island or somewhere out of aus for my wedding so she doesnt have to invite my dads family *meow*
Well you can definately go holiday mode - barefoot in shorts and tank top in midland gate just like the locals.
hmmm they are suppose to be quieter when they are hot not louder i thought - yeah me and my mechanic went doing mini burnouts to try to get them hot enough to stop squeeling - didnt work but had fun :D
koh sumoi - i was suppose to go there haha with a friend because he gets flown over there by his fathers company to spend time with them - dad works on an offshore oil rig. But i kinda started going out with a guy and that was the end of that idea.
Originally posted by GTS-t VSPEC
15 cars is alot, I don't think we need to over do it, beside, most of those Silvias are plain and boring looking:D
See'ya:burnout:
true.. :D
i'm sure 8 or so lines next to each other will cause a decent stir... :(
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
