  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh the sr20 is a better engine but u do pay for what u get. Imagine a fwd sr20, eeekk horse and carriage. Got the guy down to 1200 with no gearbox. but i will need an safc to fool the afm into thinkin the injectors arent bigger. Can u PM me mr mayhems number? i want to get the ball rolling by the end of the day.
dont lose your license paul haha this taxi is already booked up.
Shuto yeah my stereo system is good but not drool worthy - need decent set of back speakers at the moment but have more important things to buy so they will have to wait.
Anyway lunch time for me - see yall later.
