  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
thanks ken - well the alcohol definity helped the smiling part hahahy by the end of the day my face was sore from smiling hahaha
Bet you were sore in the morning( the feet Troy , not what your thinking , dirty boy :( ) when the affects of the booze wore off.
Cheers
Ken
Cheers Ken.
Got pics from a guy selling front pipes & the pipe is much longer than what mine are & have the hole to mount the oxygen sensor. My front pipes are very short with the oxy sensor mounted in behind the cat.
Just curious to know whether my cat is further forward than normal or if it's cos there is a difference between the 32 & 33?
Cheers
Ken
hahaha I was thinking something dirty when I started reading that hahahaha. Yeah I was a bit hungover but nothing a full buffet breaky didn't fix!!! hahaha
Originally posted by Micko
Cheers Ken.
Front pipes , you mean the bit from the back of the turbo that does a 90deg bend or the two pipes that come off those and join into one before the cat ?
Cheers
Ken
You posted earlier that your dad paid for honeymoon somewhere. Have you been and are back already .
Cheers
Ken
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
