  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
thanks ken - well the alcohol definity helped the smiling part hahahy by the end of the day my face was sore from smiling hahaha
Bet you were sore in the morning( the feet Troy , not what your thinking , dirty boy :( ) when the affects of the booze wore off.
Cheers
Ken
Cheers Ken.
Got pics from a guy selling front pipes & the pipe is much longer than what mine are & have the hole to mount the oxygen sensor. My front pipes are very short with the oxy sensor mounted in behind the cat.
Just curious to know whether my cat is further forward than normal or if it's cos there is a difference between the 32 & 33?
Cheers
Ken
hahaha I was thinking something dirty when I started reading that hahahaha. Yeah I was a bit hungover but nothing a full buffet breaky didn't fix!!! hahaha
Originally posted by Micko
Cheers Ken.
Front pipes , you mean the bit from the back of the turbo that does a 90deg bend or the two pipes that come off those and join into one before the cat ?
Cheers
Ken
You posted earlier that your dad paid for honeymoon somewhere. Have you been and are back already .
Cheers
Ken
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
