  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Thanks micko
Ken - yeah its been a big secret from me. Dad got it for us for the wedding present. I totally wasn't expecting it. Me and drew were going to save up and go later in the year. We are going to thailand. I would have been happy going to margs for the weekend!
Originally posted by Micko
No, not the dumps, the pipes between them & the cat that go from 2 to 1.
If your front pipes end just rearward of the gearbox mount then that is about std.
Are you sure the ones he has are not replacing the cat at the same time.
Cheers
Ken
Originally posted by Sneeza
Thanks micko
So have you gone yet ??
Cheers
Ken
Hmmm...good point Ken, could be complete cat replacement.
Either way I'm not gonna spend over 300 bucks on them cos I don't reckon they will fit.
People keep telling me that I should get a small gain in power & better throttle response by repllacing them - been told the first metre of your exhaust is the most important.
kyles - well my parents are separated... so mum couldn't afford much. She helped a little, which I so appreciated. My dad paid for the reception... but he's a pilot so he can afford it and he owes something to me. But drew and I have put off buying new clothes etc stuff for the house for over a year saving to pay for the wedding hahaha ohhh there are so many shoes I want to buy
Yea but the first meter includes the dumps off the back of the turbos which is where your biggest gain will come from.
Cheers
Ken
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
