  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Heloo sexy hansome spunky bum troy :D
I got that candelabra for amber. I wanna keep it but. Its too nice. I bumbed into mum while i was shopping.
Hehe.. and i counted 6 guys staring at me. When i walked past the secutiry gard I heard him say "holly shit" his eyes on my tits as i walked pasted
