  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Your lookin forward to meeting my ole Dad, the ex hippie now baldy!!!!!!!! No-one looks forward to meeting him, only to get there cars tuned is what they are looking forward too! Nah, he is pretty good at dyno tuning, you are taking your car to the best if you take it there!
no he meant stay away froim the guys on here cause your a 18yer old blonde! hehehee nad by the way ur older then me :)
i jsut remember i am second youngest, the youngest uy on here Boosted_RB26 owns a r32 gtr the basterd :D hehehe nah he cool!
troy welcome onboard the bourbon boat! hehehehe cougar? beam? or my good friend jack daniels?
anywho i am off to the gym now so whore yas later on!
adrian :P
if not i will see most of yous at como tomomrow at 12
