  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by R31 Chick
Thats right, you got that barbie tonight ay!!  Sorry, got other plans.  I'll let you have one less.  I didn't ignore ya either, I told ya Adrian had gone, come on!
Hey i didnt say you were invited :):D
LOL ITS OK!
Joes going to woolies and then a petshop...
hang on...i cant remember him having any pets?
Originally posted by Nizmo
Macka - you trust Joes meat haha?!
I'll get bread rolls etc if u wish.
Paul sure what do u want?
Thanks sweety...
Paully Yes i am gay..Dont you remember last friday night?
See you 330 then down the tav with the trevs
Hey skyzerr got to give him credit :)
or maybe a shovel hehe
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
