  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
couldnt find these weights on wheels today - saw mag, saw tyre, saw shockies, saw metal rods, saw springs, saw cobwebs, saw little plate on mag with 10/10/10 on it - but that was about it :(
Originally posted by Micko
Sheesh - you're sharp tonight young lady - good work...don't reckon most ppl will get that one though
AS I said last night , that conv is buried and way barked it's use by date.
cheers
ken
haha yes it was meant to be subtle :( (and yes i do know the meaning of the S word) haha
Gee whiz old man - don't act like I'm the pain in the ass that I am - surely you knew that when you sold me a car?
Anyways, question is this: there is a shitload of piping on the GTR; balance pipes between the turbs, etc, etc. Makes working on the car tricky & ppl tell me that it is mainly for emission control - can you tell me what can go & what needs to stay in order for the engine to run properly?
Ahhh , sometimes it's so hard ....
Those little 10/10/10 plates means ypu have 30gms of weights on that wheel.
God you must be good , cos sometimes your SOOOO blonde.
hehehe
cheers
ken
I did a THOROUGH detail of the inside after that i lost all motorvation, looked for these thingies on wheels but couldnt find them - not that i had a clue what i was looking for in the first place - so i'll do the rest of the cleaning in bits n piece thru out the week - might even take train to work so car stays nice n clean once its done
micko im not sure which hoses u can remove in a GTR but i did a cleanout of my engine bay over the last 6 weeks and its made a big difference to appearance and i can see the oil filter now too! not to mention changing the spark plugs is no longer the 30min job it used to be with all the crap over the cams
hehehe
cheers
ken
oi i know more than the average female
Im still learning
and daddy only bought me the cars he never showed me how they worked.
ok so the plaque are the weights cos its bloody small if it is - or it just telling me i should be going looking for 30gm weights elsewhere on the wheel? 30gms - thats nothing how the hell does that give the problem im experiencing?
Sorry Micko , missed the :( on the end , wasn't meant to sound like you are the pain in the arse.Hehehehe
Balance pipes ??
A lot of the pipes are oil and water lines that run between the terbs and are essential for terb wellbeing.
Not much emission stuff around there ??
Don't know who told you that and YES , they are a pain to work on. That's why I'm getting the engine pulled ( yes , some thing else I pull as well Niz:D ) to do the terb swap .
cheers
Ken
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
