Originally posted by adam 32
hey ken, ive heard u know a bit about speedworks. do you know if they can tune HKS F-Cons now? apparently some bloke learnt from the JUN tuner how to do it...
It's Andrew Jordan and Glenn Sumich pwpt60secf.
Glen is the salesman and Andrew is the computer boffin who Mr Jun prolly showed in his broken engrish how to tune the f con.
Mr Jun thinks the f con is good and the Apexi Power FC is not so good.
Go figure.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Thanks Ken.
I was looking this arvo & there is a pipe between the inlets of the two turbos just near the compressor which I assume is a balance pipe. There is also heaps of crap under the plenum that must be useless. Also, there are pipes that go right over to the front where the bov's are. Seems over the top cos I was checking out an RB26 at the track today on an R32 & there was heaps of room under the boonet.
Originally posted by SHUTO-BOY
micko: theres even more stuff inside a gtst engine bay,.a jungle
hmmm trying to give my engine bay a scrub today cos as u know from looking under it theres sand dunes in there - but too many hoses and stuff got in the way so i thought bugger it i'll do it a day when i have patience :(
Fabio - shut up!
Niz , soory was just trying to get sarcasm points up while you lot were recovering from your nana naps.
5 gms can make a difference but each wheel is balanced individually so the weight will vary.
Only way you will know is to get them rebalanced or swap front to rear.
cheers
Ken
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
