  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Oh and Adam , read my post , if Glenn is the salesman and Andrew is the computer guru , then take a guess who is going to prolly tune it.
Put it this way , Niz prolly knows as much about F Cons as Glenn.
Cheers
Ken
no the balance and the alignment made it smoother but did not fix the problem when i hit 80kms + it didnt make it worse nor better the problem was just the same.
kono kikai o shuri suru toki, sono neji o hazushite kudasai.
Originally posted by Micko
Back in a while - gotta force myself to eat the gourmet delights that the boss is serving up:)
Ooooohhh , the mind boggles .
* thoughts of Naomi on rye , *
Cheers
Ken:D
Ok , the car had a vibration at 80kmh + and you took it in.
They balanced all 4 wheels and aligned it AND put the fronts onto the back.
The vibration at 80kmh + is still there ?
Read that carefully and answer.
Did they drive the car , found it had the vibration still and THEN put the wheels onto the back or did it all at once.
cheers
we will get there
Ken
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
