  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Boostzor
Oh so thats what the avatar is about eh int21H? i was wondering what that was.
U still have a limiter huh? thats gotta suck. But u know that if the needle hits the other side of the 0 its busted for life, it jumps all over the place all the time.
Is it hard to read?
Hehe, yeah i won't make it brake the needle.
Shuto, i would buy an RB25 box, but theres a bit of price difference. I'm finding difficult to afford fuel in the 32 as it is
