  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
This might sound dumb , but you haven't lost your phone , smokes , lighter or something ?
there might be something under the console.
That or the last rollback bent the fork.
Cheers
Ken
nah i pulled the console partially off to have a look, but i'll do it again tomorrow. I'd hate to drop the box and find a lippie or lighter stuck under the stick somewhere.
Originally posted by GTS-t VSPEC
Aidwin,
HPI6 is out, but the Spoiler Shop had to send all there copies back, cause they didn't transfer right.
See'ya:burnout:
Hmmm , I got HPI 6 yesterday on dvd but haven't even looked at it yet.
Cheers
Ken
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
