  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
This might sound dumb , but you haven't lost your phone , smokes , lighter or something ?
there might be something under the console.
That or the last rollback bent the fork.
Cheers
Ken
nah i pulled the console partially off to have a look, but i'll do it again tomorrow. I'd hate to drop the box and find a lippie or lighter stuck under the stick somewhere.
Originally posted by GTS-t VSPEC
Aidwin,
HPI6 is out, but the Spoiler Shop had to send all there copies back, cause they didn't transfer right.
See'ya:burnout:
Hmmm , I got HPI 6 yesterday on dvd but haven't even looked at it yet.
Cheers
Ken
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
