  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
This might sound dumb , but you haven't lost your phone , smokes , lighter or something ?
there might be something under the console.
That or the last rollback bent the fork.
Cheers
Ken
nah i pulled the console partially off to have a look, but i'll do it again tomorrow. I'd hate to drop the box and find a lippie or lighter stuck under the stick somewhere.
Originally posted by GTS-t VSPEC
Aidwin,
HPI6 is out, but the Spoiler Shop had to send all there copies back, cause they didn't transfer right.
See'ya:burnout:
Hmmm , I got HPI 6 yesterday on dvd but haven't even looked at it yet.
Cheers
Ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
