Originally posted by DCIEVE
wherebouts does cruise start from (time?) should be pickin up my car today or tomorrow just waiting for parts so can pass pits.
If you are talking about the cruise this friday night..... It starts at 8.00pm and starts at City West....
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam gears? I'll find out today what is happening. Loosing the variable cam timing isn't a big deal, in fact once you do cams then it's the best way, I'll speak to Steve and see what impact he thinks it would have if you did both inlet and exhaust on standard cams:D
See'ya:burnout:
U really cant just call em up on the phone and ask em to do something illegal. Exhaust torque got fined big a while back and they wont be doing it again. For all they know u could be EPA calling. Cats dont make all that much difference y not be environment friendly?
Yeh i know what ya mean there. Thing is if u want quality u gotta pay for it, there are really no shortcuts.
Hey if u can weld its not too hard to just weld straight piece of pipe through ure cat so it looks legit. Its gonna be a task finding a shop to do it for ya.
U just run ure zorst straight through and use the old cat casing to put around it and then weld the ends so it looks real.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
