Originally posted by Pva_Glue
Those chicken are fed steroids so they can bulk up most amount of muscle in shortest time...
or even sicentist made featherless chickens... so they dont have to pull the feathers out ... lazy! hahah.
there not suppose to do that anymore
can lead to the birds have msg which can poison humans
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
is it even chicken?
They are genetically modified chicken!
last week in my molecular biology... we had to test the contents of pate made from quail meat.
work out how much quail meat in the pate. by diagesting the DNA contens with enzymes then comparing with known DNA of quil...
hahahah its very complicated process and boring!!!
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
