Make it ureself even. the only logical reason is for the Salon in which case it need to look nice and all.
Oh and when u first install it make sure u carry a fire extingusiher on the maiden voyage. u never know
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i jsut used to order my lunch and hughsies lunch to come together eat it in the office n surf the net - the days before whoring :) i used to walk the hill a bit too but going past broken hill is really dodgy.
Originally posted by Nizmo
$293 on beer - i think your going to need some help drinking that much beer *hint hint* haha :)
I need no help
FOOLISH MORTALS BOW DOWN BEFORE THE ALMIGHTY BPU.:bahaha:
Hey if ure not driving ill prolly be hanging out of gradenkos car like a goon. illl toss a berr ure way tomorrow. if it doesnt rain.
GTS-t VSPEC, vacum through the oil breather hose? I sure hope you've blocked off/pulled out your pcv valve, cause otherwise you're just sucking oil vapour and unfiltered air back into the plenum chamber. If you've yanked the pcv, then there shouldn't be much vacum to worry about.
I'd still be getting heavy duty hose instead of the clear stuff. Looks a whole lot more "stock" whith thick black hose and no chance of hot oil causing problems.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
