  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
well I'll be making my side of bargain Wild Turky I promised... and the Turky you will get!
You will be supprised I hope you have a cage in your house :D hahahahhahahaah
As long as it doesn't gobble , gobble , gobble too much then macka will be happy.
Abit of licking and sucking will please him even more.
cheers
Ken
Originally posted by macka
Cage ? is that for the the sphincter of the universe...
thats ok we'll all wait out the front in the bushes and come out when the parents have left....
Hasn't stopped you hiding in the bushes there before so what's different now ?
Cheers
Ken:D
Originally posted by GTS-t VSPEC
Ken,
Nothing wrong with gun-metal grey GTR's I'll have one if your giving them away:D
See'ya:burnout:
Nope , gave the last freebie to Micko.
Simmo paid dearly for his ( not ):D
Cheers
Ken
cheers
Ken
I dont knowabout sucking but it's kinda Frozen hahhah... he will get freeze burn if he touch with his body...
Paul- I thought you running your car at 1BAR!!! :D
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
