  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Naomi will be out till a bit later, that's why we're allowed to have the house:D
See'ya:burnout:
Bugger the house , wheres Naomi going.
Micko can watch vids by himself :P
cheers
Ken
Originally posted by gtrken
Greande ??
yeah Grenade... it's the term young folks use
Taking grenade - doing something no one would do!
eg... two chicks in the club and ugly one and bautiful one...
so you and your mate do rock cissor paper looser get to take grenade...
does that make sense?
Originally posted by macka
U never know if joe drinks straight bourbon he might be running around naked......hahah
eeww
double ewwww
Do NOT , repeat do NOT give Joe bourbon.
I don't want to waste a beer when I puke at that sight.
Cheers
have some class
Ken
It does but you posted
GREANDE
not GRENADE
does that make engrish?
Cheers
Ken
double ewwww
Cheers
have some class
Ken
hahah Trust me boys I wont be drinking any alcholic beverages...
I'll save my self humiliation for saturday :P
Originally posted by Neo
This Place is like a magnet Gday guys.
Troy - what u doin thinking about sellin line for house u have just forked out for diamonds that should keeps you sweet for a while?
Micko - Your a phantom
nah not selling the line
but thats the only reason i would
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
