  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
I got all that and more.
I practise on myself ( cos no one else will )
Have a house
Got a R64 GTR ( 2 x R32's )
Gotta a wife ( want one ?? )
No Kids , thank ****
cheers
Ken
Ken you are missing out on fruit of your life! the KIDS!!!
You have to pass on your genes!
It's not too late mate! you may able to clone your self :P
Originally posted by Adrian_perth
yes neo,  i am keeping wraps on what i am doing to my babe, hopefully all turns out well yall all see!
whhhhhhhhhhhhhhhha titanium catback? you building a drag car for hks or sumthin? how much that setting ya back what brand is it?
adrian :P
Shouldnt have secrets from fellow liners:D
Its a Apexi N1. Just trying to keep up with you adrian:p
Originally posted by Micko
Shall I come & pick you up once you're drunk macka? You can be a right clint when you're pissed.
Ken - check you're last post matey cos methinks you forgot to fix a typo - better go back & sort it out;)
Typo ??
what typo ?
* zoom , what was that *
Cheers
Ken
ewww puhleeze. Another one of me.
I would strangle him at birth.:P
Nope , the world is screwed and why would I bring up someone I love into it because it supposedly the *done * thing when your married
Cheers
only serious post for the night
Ken
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
