  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by rob77
His dad used to coach marcus, my cousin and me privately cos we all looked like going on with it, marcus was the only one that made it, I gave it up to concentrate on my tee scores and I regret that now :D
i did this with golf, sort of regret it but not to fussed as i know i didn't have attitude to practice as much as i would of had to.
3 handicap at age 15
Hi peeps , bye peeps.
Just spent all day on the bloody GTR.
Pulled off inlet manifold cos it had spat No6 throttle body gasket.
Finished at lunchtime , fire it up and found that the rear turbo gasket had gone too.
Have JUST finished. , 4hrs for the inlet , 9hrs for the turbo gasket. Not fun and I'm glad I didn't have to pull off the front one , thats worse.
Anyway , I'm knackered and going boating tomorrow so bye all.
Cheers
Ken
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
