Oh no, it was your 2nd car, what was your 1st? A VW convertable finished in a nice shade of pink!!! (hehe!)
You want me to tell you what I have heard about you? I wouldn't go there! If you want a story on me, you won't get one, you don't know anyone I went to school with.
How is Cher anyway? (hehe!!)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by R31 Chick
Hay, I have lots of stories, don't push it or they will be on here for the world to see!
that's quite funny hey, as I went to school with my mate Psiker too... now THERE could be some incriminating stories (mostly about ex-gf's, but nevermind that)
a 1981 Ford Cortina Ghia.... yeh babay! RWD 2.0L N/A power!!
it was Red actually....and was quite fun in the wet.. hehehe
best you PM me with an embarrasing story before you post it eh?
What is Psikers real name?  My b/f and Dan and Phil probably know him to then hay!  More stories, yay, I love stories!
Still no stories on me!
Ahhhh.... you'll have to ask him yourself :)
tell me your last name and what school you went to, give me a few hours and i'll have you sussed :)
Originally posted by Strich9ine
Dam, there goes my life ambition, yeah that's right, I was planning to stalk you....
Well, you just never know, from what I heard, hmmmm. Nope, last name and what school stay a mystery!!! Oooooooo!
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
