  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ross from works auto put one of those hurricane filters on for me yesterday, they are supposed to be a huge improvement over the HKS pod filter. Driving home tonight I'd put my foot down with 12psi of boost and it'd cut out as soon as it hit 12psi, so I dropped it back down to 9psi and it was misfiring bigtime at the top end and didnt feel like it was pulling past 5000rpm... any idea's? think I'll go back to the HKS pod and get a refund.
Originally posted by Sneeza
Ken - did Jeff say anything to you about the car and what i said?? I hope I didn't get you in  trouble
Nah , Jeff wasn't there and as I said , it's not a problem.
Only saw the car you were looking at outside in the dark and rain.
Didn't look too bad but can look at it closer once you decide if it's the one you want.
Cheers
Ken
Lack of restriction causing overboost and lean mixtures.
Seems strange cos I didn't think there would be that much diff between pod filters.
Cheers
Ken
kyles - the sleep over thing was cause you said you were going to bed alone - so ken was gonna come and keep you warm hahaha
I'm not good. I am not doing solo's in the nationals (i haven't got the guts hahah) I am doing three team dances...hard to explain.... Have you seen river dance??
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
