  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
no he has done nothing to it. Its got a 10stacker and bbs mags thats about it really. The engine is basic stock
trying to get someone to buy it to avoid the hard decisions Liz ?
If the one jeff has is the one you really want , go for it. It comes with a warranty and just mention the SAU guys will blacken his driveway if he stuffs you around. Hehehe
cheers
Ken
