  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oh yeah i have a conscience - no brain just a conscience haha. I just dont feel that im going to go to hell cos i slept with someone out of wedlock - or swore and cursed or i didnt bible bash other people.
yeah im going to the pub for afterwork drinks with my mate tonight - im driving tho :P
I went thru a booze bus last night - thursday night at 7pm on Roe Hwy - i only go thru them on weeknights! Havent been thru one yet at a time i would be drinking!
getting a bit better...
had a call from work - they had a meeting and said "hey, cam's just been to asia right? And he's got the flu right?" - next thing i get a call saying make sure you're well before you come back.. I said thanks for caring man.. he said - no i don't think u understand.. make sure ur WELL...
i said the dreaded sars word (i did get checked for it by the way) and he said that a few people at work had seen me sick and were quite scared.. funny huh?
