  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
What is it? i think 35 is the limit. Dont ask me 35 what, i dont know:rolleyes:
So u just in the wrong place wrong time eh? well it could have been a speeding ticket so at least this will save ure lic a bit. Look on the bright side of ahole cops.
THE GIRL'S PRAYER
Our Cash
Which art on plastic
Hallowed be thy name
Thy Cartier watch
Thy Prada bag
In Myer
As it is in David Jones
Give us each day our Platinum Visa
And forgive us our overdraft
As we forgive those who stop our Mastercard
And lead us not into Katies
And deliver us from Susans
For thine is the Dinnigan, the Akira and the Armani
For Chanel No.5 and Eternity
Amex.
paul,
dont think Aidwin got done for speeding. I think he got reamed for not having p-plates up.
so is the summons for speeding??
Id be taking the car to the place that did the tinting I reckon. getting them to provide a written appraisal of the level of tint, which you can show to the guys at the pits.
As far as the legal requirements, theres quite a lot about modification on the dotars and the dpi websites.
I think the dpi site goes into tinting and stuff...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
