Bayley/Paul,
thanks for that mate. blue neon. gonna have to do something about making it look less like a neon I think.
that neon on-off switch got some workout over the weekend, wot!?!!
Paul,
I reckon they gave you a sticker based upon aesthetic issues. It either looks too tough or too ugly. I cant quite decide.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The dude at Warnbro Autos went over that 31 with a fine tooth comb and found bald tyres and the lower control arm bent which we done when the clutch went trying to get it up the ramps. The clutch slipped so bad that it couldn't drive up like normal so Jeff just smashed it up. He didn't care cuz he hated the car.
Very polite way of putting it Boostzer. My way would be more like, I only just got it over the pits. Well, your tyre on that police bike looks bald too. You won't find anything, we just passed it ove3r the pits. Guess who got a yellow anyway.
They use this little paper thing and if they can't see it clearly then you get done for it. Try telling a cop that your grade 5 limo tint is legal! Didn't work. Silly cop told Jeff that he had a oil leak from a air conditioning hose to!
Go down Dixon Rd heading away from Rocko into Kwinana. Go straight through the Ennis Ave lights (corner with Toyota Ways on it) and take your 1st left. Follow that to where it does a 90 degree bend and you will see Marino Mechanics right there straight in front of you.
Being polite wasn't working so I had to try something!
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
