  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey there russ, rob, ken, anyone else...
Ken - I got enough backlash in my rear diff that I should get it attended too. Had the car on a hoist at a local performance shop the other night to check it out. I was told that it was prolly something to do with a spacer type thingo (sorry cant remember exactly) that would need to be replaced inside the diff where the tailshaft connects. I think it is compliments of a lack of experience launching the car from the one time I went to the drags.
Anyway - to cut a long story short - can you tell me where to go?
Yep can do but your wife has already done it for me...
Is the diff noisy?
The spacer thingy is probably the crush washer for the pinion bearing.
My advice is to just turn up the radio a bit louder. Removing , o/hauling and while it's apart , replace the clutch packs , carrier bearings , reset the preload etc then the figure will be in the $1300- $1500 region.
Get a 2nd hand one and be ready to throw it in if you run out of radio volume.
Cheers
Ken
Originally posted by rob77
My driveshaft needed 3 new unijoints when it got here, they were all fubar'd and made the car vibrate. Place in osborne park machined them and replaced them for around $360 all up. Driveshaft Balancing I think the name was.
One of the few places I know is Diff and Trans in Jolimont.
Know a few tailshaft mobs but they are not diff rebuilders.
Cheers
Ken
Thanks guys.
Ken, there's no noise, & I think it was the crush washer that they were talking about. I wouldn't care about it except that I was told it could cause excessive wear on the crown wheel (I think that's what it's called).
But then again - drive it till it breaks then get one 2nd hand for around $500 bucks I reckon.
Originally posted by Micko
Thanks guys.
Zachary...
You one smart cookie boy:D
Cheers
Ken
Ken - I'm gonna check out Gav's mines ecu on sunday & will prolly be doing a deal with him. He reckons it gave him around 300rwhp on SST's dyno.
In conjunction with what.
Std they are around 200-220 hp at all 4 . Would be surprised if just a puter made that diff.
Cheers
Ken
Originally posted by 33Spec2
haha so true ken!:D where paul and aidwin these days? and they call themselves whores!!
Paul and Aidwin , both MIA.
ewww , that conjures up some horrible images.
No Niz either. Hmmm , a 3 some.....
Cheers
Ken
Let me know if you stumble across a diff in your travels Ken - if you see one for the right price it would be worth me buying for when either of us have a need for one :D
I gotta spare , it's in the ricer.:D
Actually ,C Red have a few for around the $800 mark and I think they may even have a 1.5 or 2 way.
Cheers
Ken
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
