Ooohh looky what i found. This is something i have never seen at the motoplex http://files.franzonline.net/images/ it has some nudity in it so no direct links but tis the holly shoot to set u on the right track.
Oh yeh none of these pics are worksafe so open with care.
Does any1 know the 33 there?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i had this bitch in a Honda (Y is it every dickhead drives a honda) sitting in the right hand lane next to a truck today blocking it so nobody could get past. After sitting up her arse for 10mins i decided the truck was probably going faster. So i got behind the truck and the two lanes were merging into one - so i decided to be a bitch back - she was going to try and get in front of me behind the truck but i blocked her. So then she finally decided to try and overtake the truck but the truck decided to merge lanes early and came very close to crushing her car - she jammed on her brakes let the truck go past - by this stage i hung back a bit - cos i did my job gave her the fright of her life - anyway she got up the trucks arse - truck jammed on its brakes and she nearly went up it. I was pissing myself laughing the little bitch got totally what she deserved - im not normally that mean but dickheads who havent got a fricking clue about road rules and dont show common courtesy to cars dont deserve any kinda courtesy back!!
:P GRRRRRR
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
