Ooohh looky what i found. This is something i have never seen at the motoplex http://files.franzonline.net/images/ it has some nudity in it so no direct links but tis the holly shoot to set u on the right track.
Oh yeh none of these pics are worksafe so open with care.
Does any1 know the 33 there?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i had this bitch in a Honda (Y is it every dickhead drives a honda) sitting in the right hand lane next to a truck today blocking it so nobody could get past. After sitting up her arse for 10mins i decided the truck was probably going faster. So i got behind the truck and the two lanes were merging into one - so i decided to be a bitch back - she was going to try and get in front of me behind the truck but i blocked her. So then she finally decided to try and overtake the truck but the truck decided to merge lanes early and came very close to crushing her car - she jammed on her brakes let the truck go past - by this stage i hung back a bit - cos i did my job gave her the fright of her life - anyway she got up the trucks arse - truck jammed on its brakes and she nearly went up it. I was pissing myself laughing the little bitch got totally what she deserved - im not normally that mean but dickheads who havent got a fricking clue about road rules and dont show common courtesy to cars dont deserve any kinda courtesy back!!
:P GRRRRRR
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
